SRVCC Configuration: Can It be set up like Blind Handover or only with Measurements?
Can SRVCC be configured like blind handover?
Or can it only be done with measurements?
Yes, but you don’t want that.
Why??
What if the cell you set it as blind, it was faulty and OOS?
Sorry for my low level, but could you give me few details…?
Let’s assume you set up cell A in 3G as blind, so the UE is going to perform SRVCC to this cell A no matter what.
This cell A was facing a hardware issue, and it was off.
What’s going to happen?
mmmm, Okay, I get it. thanks a lot!
