Dear reader,
If there is a Inter-SGSN RAU for a device with Active PDP session, will the TEIDs in the update PDP context change (since new tunnel between GGSN-new SGSN) or will it remain the same?
Thank you for your response.
Dear reader,
Charging ID in GGSN | 0 | 562 | December 23, 2021 | |
Change in Subframe Type issues? | 0 | 430 | February 20, 2020 | |
Same URA belonging to different RNC's | 2 | 697 | August 27, 2020 | |
5G cells with the same PSS ID | 1 | 492 | October 12, 2022 | |
UE Behaviour during different RU handover | 0 | 596 | December 13, 2021 | |
Network disconnection when changing RAT | 0 | 283 | January 9, 2023 | |
How to know if the RRC Connection Reconfiguration belongs to Intra-SgNB, Inter-SgNB or Addition request process | 1 | 410 | August 16, 2021 | |
RRC signaling based BWP switch in case of TDD system query | 1 | 625 | June 19, 2020 | |
Mac layer changes for FDD vs TDD | 0 | 657 | October 23, 2020 | |
Why does an on going call have to change the radio link delete request? | 0 | 784 | October 13, 2017 |
