Telecom Calculators
Wireless Frequency Bands and Telecom Protocols
Frequency / ARFCN caculator for NR, LTE, UMTS, GSM, CDMA and Carrier Aggregation combination. 5G NR Bands, Carrier Aggregation, Dual Connectivity. LTE Resource Grid, Bands, Bandwidth, Carrier Aggregation, CA spectrum, FCC spectrum, Proximity Services, Dual Connectivity. UMTS, GSM, WiFi and much more.
Author:
https://www.linkedin.com/in/laurent-guillemot-1b906b5b/
5G Tools for RF Wireless
Tools from engineers for engineers
Author: Vinogradov Oleg
https://www.linkedin.com/in/oleg-vinogradov-18713492/
Antenna Horizontal Isolation Calculator
A tool to calculate Horizontal Isolation, distance between two antennas of different or equal frequencies. The calculator provides an estimate of the isolation provided by two horizontally separated antennas.
PIM Calculator
This Tool will make your life easy while calculating and analyzing PIM (Passive Inter-modulation) in your DAS solution.
Author: https://www.linkedin.com/in/ruchira-perera-68882512/
4G Theoretical Throughput Calculator
4G Theoretical Throughput Calculator Calculate the maxium theoretical throughput of a specified LTE Configuration. Supports TDD, FDD and SDL, Carrier aggregation and MIMO.
Open Source: GitHub - jake-cryptic/4g-speed: 4G Theoretical Speed Calculator | FDD & TDD Support
Author: https://www.linkedin.com/in/jake-m-268b75172/
5G Speed Calculator Demo
5G Speed Calculator [Beta]
Open Source Code: GitHub - jake-cryptic/5g-speed: 5G Speed Calculator - Support for all of the latest FDD, TDD, SDL & SUL NR bands
Antenna Downtilt and Coverage Calculator
https://www.pasternack.com/t-calculator-antenna-downtilt.aspx
The Antenna Downtilt and Coverage Calculator (aka Antenna Tilt Angle Calculator) is used to determine the approximate downward angle, measured in degrees, which the transmitting antenna is to be positioned for optimal signal strength and coverage. This antenna tilt angle calculator also provides, given a beamwidth, the inner and outer radii of beam’s coverage.
LTE-FDD Capacity Calculator
https://lte-fdd-capacity-dimensioning.readthedocs.io/en/main/ltefdd-capacitycalculator/
LTE-FDD Cell Capacity Calculation guide (documented with a calculator)
It describes all overheads and how the RF conditions (like CQI, IBLER, Rank) affect the overall Cell Capacity.
Open source documentation and also Calculator.
Author:
RF and Wireless Converters and Calculators
This page of RF Wireless World covers converters and calculators. These are very useful as it provides easy calculations along with example and formulas or mathematical equations.
Example: 5G NR ARFCN vs 5G NR frequency conversion calculator
