This guide is aimed at both first time users or experienced users requiring a help on telecommunications.It is intended for anyone with desire to collaborate, to learn and to share ideas using Boda Tool and having Community Support.
It is structured in Topics. Here you can follow the links to all the documentation for Boda Tool and Telecom Experts Best Practices.
Introduction to the Project
telecomHall Experts Handbook - Introduction
- Never heard about Boda before? This is a good place to start: telecomHall Experts Handbook - Introduction
Open Source Telecom Project - Tools and Best Practices
- Here you can find a good summary, a more detailed overview of Boda: Open Source Telecom Project - Tools and Best Practices
Boda Roadmap
Boda: Roadmap (Past & Future)
- Here you can find all past and future: telecomHall Roadmap (Past & Future)
Installation
Here you can find all the latest version for both Boda Lite & CE edition. NOTE: Installation is default - simply follow instructions on screeen. Update: Only Boda Lite is working, all other initiatives stoped, see this post explaining Boda Lite - Multivendor/Multitechnologies Network Management Tool (CM, PM and more) - #20 by Emmanuel
Boda CE
The CE (Community Edition) was the first version of Boda.
Our Community decided to first develop a brand new version: Boda Lite - a lightweight version of Boda CE, installed in a computer, and processing it all locally (ability to be used âofflineâ based on input collected data - raw data). So, the installation instructions for Boda CE is currently postponed, and weâll let you know here when itâs available again.
Boda Lite (latest version to DOWNLOAD)
Boda Lite: PosgreSQL Database
DEPRECATED! Please see reason here - Boda Lite - Multivendor/Multitechnologies Network Management Tool (CM, PM and more) - #20 by Emmanuel (In short our solution does not use Databases anymore; in fact, weâre using a much better approach wit Python)
Although not ârequiredâ, itâs highly recommended to install a database to use Boda Lite features (audits, reports, etc.). Here you can find the steps to install it on your laptop.
http://www.telecomhall.net/t/boda-lite-how-to-install-posgresql-database/5749/ (Deprecated, here only as REFERENCE).
Using Boda
Boda: Key Parameters
One of Boda features, âKey Parametersâ represents a simple list will all cells and their most important parameters.
One can for example have quick access to all network (vendor/rat) most important parameters.
Important parameters usually come from several MOs (and require SQL queiries to join information from all the MOs.
This feature do this: present you with preloaded queires, showing you your network Key Parameters!
Guides to get raw data from Network
Step by step guides to get CM data to process with Boda
CM Configuration Management (Parameters)
Get Huawei CM Data
Get Ericsson CM Data
Boda - Ericsson CM Data (Dump)
Get Nokia CM Data
Get ZTE CM Data
PM Performance Management
TBD (Writing)
INV Inventory Management
Get Huawei Inventory Data
Boda - Huawei Inventory Data (Dump)
Get Ericsson Inventory Data
Boda - Ericsson Inventory Data (Dump)
Get Nokia Inventory Data
Boda - Nokia Inventory Data (Dump)
Get ZTE Inventory Data
Boda - ZTE Inventory Data (Dump)
FM Fault Management
TBD (Writing)
Traces
TBD (Writing)
Boda Architecture
Boda: Architecture
Some initial drafts for Boda Architecture
Boda: Architecture
Boda: Important Concepts
Importants concepts, but mainly if you want to install Boda CE (Server)
Virtual Machine (VM) and Containers Overview
Boda: Support
For known issues with Boda Lite (and its solution) please visit: Troubleshooting Boda Lite
If you still have any problem using Boda, you can visit the Support page:
Help & Support Center
