Hello friends… I hope all of you Ok.
I have a problem, hopefully one of you suggested a solution…
I work with TEMS pocket on test YouTube Streaming video but the script has an issue when running which is:
ErrorCause Streaming Failure Client library update required
This error is due to the pocket use mode of Android Player as a default
But it work very well when connected to TEMS investigation by using the mode of IFrame Player.
Is there any way to change the mode of streaming player in Pocket or any other solutions?
Thanks
