The move from 4G to 5G isn’t just about speed
There are subtle differences that many ignore.
Let me break it down for you.
:x: In 4G, ECM-Idle means devices are on but idle.
:white_check_mark: 5G’s CN-Idle wakes up faster.
It handles background tasks efficiently.
Less lag when you need a quick connection.
:x: When connected, 4G offers stable data transmission.
:white_check_mark: 5G goes further.
Ultra-low latency.
Higher reliability.
5G handles it better.
:x: 4G’s RRCIdle saves battery but reconnects slowly.
:white_check_mark: 5G’s RRCInactive balances power and quick reconnection.
4G is simpler but less flexible.
Deregistered states differ.
:x: In 4G, devices detach completely.
:white_check_mark: 5G streamlines this.
Less downtime.
5G redefines connectivity.
But challenges remain.
Those will be discussed in some other post.
Thanks for reading.
