Throughput issues in NR NSA
I’m writing types of Throughput issues seen in NR NSA
  1. Proper value of extended ambr not configured
  2. UE not reporting proper rank as per configured ssb beams due to poor SINR
  3. Frame structure not use properly with incorrect slot ratio
  4. 256qam power back off not configured
  5. tx end bottleneck for bandwidth
Any other issue please add here.
  • DL BLER on NR
  • PUCCH HARQ decode error at gNB leading to duplicate packet Transmission to UE
  • Device heating up leading to DL/UL Throttling
  • CSI-RS Reporting issue or Incorrect configuration
  • Narrow T-reordering timer causing Lots of packet discards at RLC in case of Very high throughputs
  • PDCP SN jump or PDCP SN not coming in order causing PDCP discards
  • CRC Failures at Some slots where CSI-RS/PTRS is transmitted due to Rate-matching issue
These are some of it that are top of my head
Hi Ankur, thanks for sharing.
Based on Huawei documentation AMBR setting can only impact NR NSA throughput in option 3 and not in option 3X. Can you please elaborate on this?
Hi Syed,
As you know typical PDSCH BLER is 10%. Is there any other optimum value for DL BLER which can result in higher throughput?
Regarding T-reordering, would you please let us know what values are considered “Narrow” and can lead to packet discards?
