I am having a problem related to Throughput and Rank3 and Rank4.
The network that I am working uses the frequence of 2500 MHz (TDD) in Fixed Wireless configuration.
The complain is about rank3 and rank4 time percentage.
Since previously this network was Huawei with rank3 and rank4 reaching up to 60% of samples, but after the swap for Ericsson it does reach even 10%.
The network site that we are analyzing is using 20 MHz + 20 MHz, with 4T4R but just reaches 290 Mbps using NetPerf.
I worked with Ericsson 7 years ago and It would amazing your support at this rump up knowledge time.
It is based on the available bandwidth.
Say 5M Hz to 20 MHz in the same cell (say 3 layers having 20, 10, 5), then 5 is what you need to consider for FDD.
Make sure beamweights are based on SRS.
Don’t know the name of parameter for Ericsson but Huawei uses SRS weights up to srs sinr = -23 dB
SRS is more precisely than csi-rs.
You may want to check antenna cables to be correct at RRU to reach MIMO rank 3 and rank4.
It is important how you correctly connect ports A, B, C, D of RRU to antenna ports +45 and -45 degrees.
Make sure I&C of Ericsson is correct regarding MIMO cables.
For Huawei, in Hedex you can look for Antenna Port Mapping table, with the mapping between logical antenna ports and RRU channels. There you find recommended configurations for different connections.
This is absolutely RF depending.
It’s not something to tune on parameters.
Only cells with rich multipath can achieve 60% rank3 and rank4.
Huawei however have hidden params to tweak/increase the rank utilisation.
Exactly, you need to have perfect RF conditions to have this.
Even if you have parameters there is no alternative to having better RF conditions.
These figures speaks of a special case but do not reflect the whole network.
