Tool for neighbor design and check PSC
Hi experts,
Ís there any free tool to design neighbor cell and PSC for 3G network?
thank for your help
Use atoll it can plane both NBR and PSC
Is atoll able to check current PSC, eg I import all PSC cells and check whether some of them are duplicated?
PSC can be reused but the distance should not be less than 5km, to avoid PSC clash and call drop.depending on the number of sites you have
You can try below mbx in Mapinfo-
  1. Distance Calculator for nbr
  2. Spider Graph for psc/pci collision check
you can use mentor SW
Thank you mate, I will try
Thank you, could you give me a link of it?
Share your email
Please can you share the video?
Please i would like to receive as well.
Thanks
Share the software
@anthony_obiora …kindly share the mbx and atoll software with me too
Hi , can u please share the same with me as well for NBR and PSC verification?
Hello can you share with me athore tool (not a tool) thanks
Br
Do you mean atoll
Another one if you have thanks (not Atoll).
Only atoll
Dears,
can you please share a document or video how to make the neighboring audit or PCI plan using Atoll tool
Hello
Would you please share this 2 tools
