Types of line-of-sight (LOS) conditions in wireless communication
Three types of line-of-sight (LOS) conditions in wireless communication are:
  1. Line of Sight (LOS):
    • Definition: A clear, unobstructed path between the transmitter and receiver.
      Where to Use: Outdoor environments, rural areas, or high towers with direct visibility.
    • How to Use: Install antennas in locations with no obstacles between them, such as on rooftops or towers.
    • Advantages:
      Strong, high-quality signal.
      Minimal interference or signal degradation.
      High data rates and low latency.
    • Disadvantages:
      Requires clear visibility, limiting use in urban or obstructed areas.
      Terrain, weather, or large structures can block the signal.
  2. Non-Line of Sight (NLOS):
    • Definition: No direct path between the transmitter and receiver; signal reaches the receiver via reflection, diffraction, or scattering.
    • Where to Use: Urban areas, indoor environments, or obstructed locations.
      How to Use: Utilize reflection from buildings or diffraction over obstacles.
    • Advantages:
      Can provide coverage in areas where LOS isn’t possible.
      Suitable for dense, urban environments.
    • Disadvantages:
      Significant signal degradation.
      Higher interference and reduced data rates.
      More complex signal processing required.
  3. Near Line of Sight (Near LOS or nLOS):
    • Definition: The signal path is partially obstructed, but the majority of the path is still clear.
    • Where to Use: Suburban or rural areas with minor obstacles like small trees or hills.
      How to Use: Install antennas where minor obstructions are present, but ensure enough of the Fresnel zone is clear.
    • Advantages:
      Better signal quality than NLOS.
      Works in moderately obstructed environments.
      Less signal degradation compared to NLOS.
    • Disadvantages:
      Signal degradation is higher than LOS.
      Performance depends on the degree of obstruction.
