Hi All.
What is the typical distance in meters between 2 antennas in a 5G fronthaul scenario?
Considering Small cell and mmWave.
Hi All.
In NR2100 MHz which the maximum distance to consider 5G-5G neighbor as good? | 1 | 513 | March 14, 2021 | |
Antenna isolation distance between two distinct Operators | 2 | 527 | October 8, 2020 | |
Transmit microwave signal over a very large distance | 2 | 418 | May 27, 2023 | |
Typical average throughput (real network) for a cell with 4x4 MIMO in 700MHz (20MHz BW) | 0 | 553 | May 11, 2020 | |
What should be normal call setup time 4G to CSFB 2G? | 4 | 1633 | January 9, 2024 | |
5G Drive Test KPIs for Antenna Comparison | 0 | 593 | January 22, 2023 | |
Electrical Tilt strategy between 4G layers | 2 | 855 | August 30, 2023 | |
Cell Range in 5G option 3 | 0 | 672 | February 5, 2020 | |
UE Behaviour during different RU handover | 0 | 596 | December 13, 2021 | |
What is mmWave coverage with beamforming? | 0 | 488 | June 18, 2021 |
