I’m deploying DSS (NSA) and I have a question related to NR leg setup.
The picture below, UE sent Measurement report to the network, but UE was still not attach to NR leg.
I don’t know why was that, does anyone have any suggestions/ideas for this case?
Thank you in advance!
Assuming this MR contains NR measurements, since you are seeing no RRC Reconfiguration trying to add the PSCELL, there is something wrong on the eNB/gNB side. Things like, missing or wrong gNB neighbor relationship, or even other parameters related to the NSA configuration. Verify your baseline.
This is also common case when UE is 5G capable, but not DSS capable. Check UE capability information for rat-Type: nr and eutra-nr to see if device is DSS capable.
In theory, if it is not capable, no B1 should be configured… but that`s theory… eNB/gNB SW is not 100% yet, especially for DSS, so I agree with you, no harm on checking if the UE is in fact DSS capable
The problem here is after sending MR report, UE did not receive RRC conn recfg to obtain infornation about 5G cell. This failure happened at enb or gnb side in 5G SCG ADD procedure, so to analysis detail, it’s better to have X2 trace log.
I think the problem may be due to some of below cause:
1, enb not send sgnb add request
1.1, enb not configure corectly neighboring 5G cell
1.2, enb configure gnb not support NSA
1.3, X2 link between enb-gnb have problems
1.4, enb’s x2 links reach maximum as vendor specific, so enb not send req to target 5g site
1.5 X2-u ping failed
2, enb already send add req but gnb not response or reject
2.1, transmission network failure between gnb and sgw, such as gnb ping to sgw failure
2.2, some parameters in add request not supported by gnb
2.3 dedicated preambles failure by 5G gnb
