Hi All.
My UE initially latch with 5G network, after 40 sec it goes to 4G coverage.
Then gradually 4G coverage reduced to no coverage.
Any help?
Any similar things happened in your observation?
Hi All.
Any help?
NR SA ue lost | 0 | 305 | September 5, 2022 | |
NR disabled by UE, expected behavior? | 0 | 436 | March 31, 2023 | |
How come 5G UE getting ipv4 public ip address though UE is latched on ipv6 only 5G-SA network? | 2 | 802 | November 17, 2022 | |
NR CA not working | 3 | 368 | March 28, 2022 | |
In DSS only 5G UE is aware of it, so whats happens to LTE UEs? | 1 | 396 | February 23, 2021 | |
What are the probable issues for a UE latched to 5G with no throughput? | 1 | 264 | August 31, 2023 | |
Value of SINR below which UE will not be able to latch onto 5G network | 1 | 434 | September 11, 2023 | |
UE doing Dual-Co but not sending/receiving any Data | 0 | 398 | March 3, 2021 | |
5G NR leg not being set up when UE in floating mode | 3 | 875 | March 11, 2021 | |
401 unauthorized message while UE is making fast return to NR attempt (SA) | 0 | 316 | November 11, 2022 |
