Is there any feature in Atoll 5G for 3D planning to let us know UE locations for potential rank4 MIMO?
Are you planning testing on a massive scale?
If not, but you just want to guess locations with possible high count of RANK4 samples I suggest location where sector is below (dense urban) clutter height
For 5G can we use 4DL4UL option? | 3 | 564 | March 13, 2021 | |
LTE Planning using Atoll | 1 | 1678 | November 16, 2022 | |
Best antenna position to maximize MIMO layers for FWA CPE | 0 | 530 | May 21, 2022 | |
UE layer spatial multiplexing in Uplink | 2 | 521 | June 23, 2023 | |
5G Coordinated Massive MIMO (Co-MM) and Clustering Setup | 0 | 17 | December 5, 2024 | |
Which UE supports 4 Uplink layers in 5G? | 4 | 195 | March 22, 2024 | |
Can we use 4x4 MIMO per user in mmWave? | 5 | 1113 | June 27, 2023 | |
How can we determine the suitable coverage scenario for 3D beamforming 5G? | 39 | 111 | October 5, 2024 | |
UE to choose the best beam without considering other beams | 4 | 1268 | March 12, 2020 | |
Is anyone aware of UEs with beamforming in Uplink on transmission for NR? | 1 | 14 | August 25, 2024 |
