One question. How is possible in attach request that UE new capability for NSA is supported and on the same message in MS Network Capability is not supported?
Someone has any idea?
Csn you make some snapshots and post it here?
Just to be sure we are looking at right stuff.
OK, so in attach request it is informing that it supports DCNR.
And what about MS Network capability, it is a little contradictory.
All 3 pictures are from attach request message?
Yes, from the same attach request.
Yes, because is optional.
MS Network capability is not part of every Attach request.
But UE Network capability is mandatory.
Ok, I found another log where both are supported.
Yes exactly, I never seen that are different in the same message.
That can be the next move
Maybe that’s why.
However, I believe sending it on MS it is not needed for this particular case.
Sounds like the UE is being extra careful.
Yes, however contradictory it is from observations with most UEs but this UE is sending accurate info.
I don’t see it as contradictory.
It is explicitly saying it is supported only in S1 mode but not support in A/Gb Iu.
It could only indicate support on S1 via UE, and say nothing on MS, as it implicitly would say it doesn’t support it.
Yes, that is what I’m saying that it is displaying correctly (and it’s good) but it is contradictory from 2-3 UEs .I have seen in DT logs where in both capability IE it shows “supported”.
Ohhh I understand now, you are comparing with the other UEs
Got it.
Ok, so it is not important in this case the value in Ms Network config.
It is strange then why there is no SgNB addition request.
Must be something else.
Did you get in attach accept restrictDCNR = 1?
