NR UEs have the 100 MHz capability for FR1. Then per my understanding when these UEs perform initial access upon power up they should be able to transmit/receive on 100 MHz. This UE post connection can switch bwp and operate in 20 MHz following the concept of bandwidth part switching.
A reduced capability UE which is referred to in NR has lower BW capabilities say 20 MHz. So they may only transmit receive over this 20 MHz bandwidth. Some questions here I am thinking about
1- assume we have the 100 MHz capable UE and they may do bwp switching for power saving, is that the same as having a 20 MHz UE to start with? In the former case, the UE is only allowed to go to second reduced bandwidth post connection. Would power savings be the same for the two cases.
2- realistically, can we have a UE with two capabilities of 100 MHz and 20 MHz. Note that this is different than having 100 MHz UE and being able to switch to smaller bandwidth part of 20 MHz.
Appreciate your insights
