Hi, per spec is it possible to aggregate 2 5G carriers in UL?
I see one vendor only brought support for 5G SA handsets. Could you pls share your opinion and experience on that? I think UE needs 2 TX antenna for that but the question UL 2CC CA is possible on 5G NSA (Handset supports both 5G SA&NSA)
Thx
LordGm
1
Related Topics
Can same cell in 5G be used both as NSA and SA? | 2 | 480 | November 1, 2023 | |
In NSA 2x2 is Uplink MIMO supported? | 1 | 527 | July 29, 2022 | |
Can we do Carrier Aggregation between two different vendors? | 6 | 897 | October 30, 2021 | |
Carrier Aggregation in LTE and 5G | 0 | 505 | July 13, 2020 | |
Do any devices support TDD + TDD UL CA in 5G NR SA? | 4 | 14 | December 6, 2024 | |
How many carriers can be aggregated in Uplink CA for LTE and NR? | 1 | 379 | June 21, 2023 | |
LTE CA with MIMO & SISO mix of cells | 2 | 640 | February 28, 2024 | |
Can SA capable UE configure to ENDC in NSA cell? | 1 | 420 | May 22, 2022 | |
NR CA not working | 3 | 379 | March 28, 2022 | |
Deploy SA and NSA sites in same cluster | 9 | 1110 | March 7, 2021 |
