Dear All.
For Speedtest APP:
It can track UE location & suggest testing server nearby UE.
So, the data path is:
- UE - eNB - Operator Core - Server
Or is:
- UE - eNB - Server
Dear All.
For Speedtest APP:
Or is:
How IE to check if the device support DSS? | 1 | 701 | February 24, 2021 | |
Does UE not sending ratematchinglte-crs IE means DSS not supported by UE? | 1 | 453 | April 1, 2021 | |
ENDC 3X UL Path direction | 1 | 323 | January 10, 2024 | |
5G UE will service requirement to gNodeB | 0 | 353 | June 22, 2021 | |
Throughput drops with increase in BLER for two NR UEs simultaneously in Lab | 1 | 373 | September 23, 2023 | |
UE not sending ratematchinglte-crs IE | 3 | 657 | April 26, 2021 | |
Measurements for NSA DC UE Mobility Cases | 0 | 554 | October 7, 2020 | |
In NSA, UE use same RNTI for 4G and 5G? | 1 | 362 | May 18, 2021 | |
Packets from UE transmitting towards gNB getting lost | 3 | 413 | June 24, 2022 | |
Throughput Testing | 0 | 582 | May 2, 2022 |
