Unlocking the Future: Innovation wrt ML-Driven CSI Enhancements for 5G Advanced/6G
  • Channel-State Information (CSI): The Backbone of 5G Performance
    • In the dynamic world of 5G, Channel-State Information (CSI) is crucial for optimizing network performance and supporting the user capacity, including for MIMO configurations as well (Multiple Input, Multiple Output) through optimizing radio resource scheduling in MAC layer.
      CSI, comprising PMI (Precoding Matrix Indicator), RI (Rank Indicator), and CQI (Channel Quality Information), provides the 5G base station, i.e. gNB (network) with a detailed estimate of downlink channel state as experienced by the mobile terminal at a certain point in time, aiding in channel-dependent scheduling.
      It is implemented in MAC layer at gNB based on CSI feedback through heuristics scheduler algorithms like proportional fair scheduling which give fair chance to all users for communication.
      It is mainly responsible for selecting modulation and coding scheme for users based on current channel conditions they are experiencing.
      It is also called as link adaptation and this particular way is termed as AMC (adaptive modulation and coding).
      CSI is sent periodically or a-periodically to gNB on uplink physical channels, PUSCH or PUCCH using different formats, consuming different amount of radio resources. This feedback contributes to overheads in terms of radio resources and may affect throughput performance.
  • 3GPP Rel-18 Study: Pioneering Network-Terminal Collaboration
    • The 3GPP Rel-18 study is exploring ground breaking CSI enhancements, including CSI compression and CSI prediction, to elevate Network-Terminal collaboration to new heights through integration of ML techniques to improve performance of this feedback loop in following aspects.
  • CSI Compression: Revolutionizing Feedback Efficiency
    • CSI compression leverages a two-sided ML model where the UE compresses CSI feedback using an ML encoder, and the gNB decompresses it with an ML decoder.
    • This innovative approach aims to:
      • Reduce CSI feedback overhead without compromising throughput performance.
      • Enhance throughput performance with the same level of CSI overhead.
      • Optimize both overhead and performance for a balanced network experience.
  • CSI Prediction: Saving Energy, Enhancing Efficiency
    • CSI prediction in the time domain allows terminals to skip channel measurements and use predicted CSI instead. This not only reduces device-side energy consumption but also ensures seamless network performance.
    • Why This Matters:
      • Improved Network Efficiency: Reduced overhead and enhanced throughput.
      • Energy Savings: Lower power consumption for devices.
      • Enhanced User Experience: Faster, more reliable connections.
  • Scope:
    • Both these features have a scope for innovative solutions and it can be further enhanced for future 6G networks.
