Hi All,
In a NR NSA network in S1_Initial_Context_Setup_Request message I found QCI= 132 under ERAB to setup details.
QCI 132 is an user definer QCI.
Do you have any idea from where I can know operator is using this service for which services.
Is it possible to know from eNodeB dump (which moclass)
Any support will be helpful. Thanks.
If you know the network topology, you can know by transport layer address in this message.
Because most all networks use diferent IP segments and physical nodes to segregate services.
Also you can look in to MBR in same message to do a fair judgment.
