The main codecs supported for 5G voice (VoNR) and video (ViNR) services according to 3GPP standards:
- Enhanced Voice Services (EVS) - This is the preferred codec for high-quality 5G voice. It supports various bandwidths from narrowband to fullband and provides enhanced audio quality compared to older codecs.
- AMR-NB and AMR-WB - These legacy narrowband and wideband codecs are supported for backward compatibility with 3G/4G networks and devices that don’t support EVS.
- H.264 video codec - Specifically the H.264 baseline profile is required for video over NR (ViNR) according to 3GPP specifications.
More advanced profiles like H.264 high efficiency video coding (HEVC) are also supported by some devices.
In addition, the 3GPP recommends that devices support the following video codecs for maximum interoperability according to GSMA requirements:
- H.264 advanced video coding (AVC) or constrained high profile (CHP)
- H.265 high efficiency video coding (HEVC) main profile
LinkedIn:
