Dear all
We currently have 30 Mhz license over band40
Can I use the same 20 Mhz channel for all EnodeB?
Yes u can use 20MHz, if possible use 15MHz make two carriers easy to load balance between same bandwidth, can better use of power as well
Ok
I will then use 15Mhz+15Mhz
Thanks
Check the full solution, actually I just proposed, the complexity/future of your network u knows better
Better use 30MHz full as a capacity layer though as band 40 doesn’t travel much ,just a thought
My enodeb support up to 20 Mhz. Its standard
