What are the impacts and benefits for changing cell from 4T4R to 2T4R?
Tx diversity gain.
Seeing significant increase in number of failure and drops as well, is it expected?
Yes, because of the decrease of Txs.
Because of the decrease of the Mimo gain, you are passing from 4 to 2 TX.
It represents less capacity,
Change from 4T to 2T will increase coverage footprint by 3 dB, right?
If coverage footprint increase by 3 dB, increasing rspower would be better solution than changing from 4T to 2T?
I think so, all depends on your RF enviroment.
Power saving with the cost of DL performance deterioration due to MRC / diversity.
And Throughput deterioration due to 4 → 2 layers.
