What are the important differences between LTE and 5G NR RACH based on different aspects?
Useful to summarize.
1. Technology Generation:
  • LTE RACH:
    • 4G technology.
  • 5G NR RACH:
    • 5G technology.
2. Deployment Scenarios:
  • LTE RACH:
    • Primarily designed for lower frequency bands and macrocells.
  • 5G NR RACH:
    • Designed for a wide range of frequency bands, including mmWave, and diverse deployment scenarios (macrocells, small cells, etc.).
3. Preamble Format:
  • LTE RACH:
    • Fixed preamble formats.
  • 5G NR RACH:
    • Flexible preamble formats with multiple configurations to support diverse scenarios and frequency ranges.
4. Subcarrier Spacing:
  • LTE RACH:
    • Uses 15 kHz subcarrier spacing.
  • 5G NR RACH:
    • Supports multiple subcarrier spacings (15 kHz, 30 kHz, 60 kHz, 120 kHz) to accommodate different use cases and deployment scenarios.
5. Beamforming:
  • LTE RACH:
    • Limited or no support for beamforming.
  • 5G NR RACH:
    • Supports advanced beamforming techniques, crucial for mmWave bands to enhance coverage and capacity.
6. Random Access Procedures:
  • LTE RACH:
    • Contention-based and non-contention-based access, primarily for initial access and handover.
  • 5G NR RACH:
    • Enhanced contention-based and non-contention-based access with more flexibility and efficiency, including support for massive Machine Type Communications (mMTC) and ultra-reliable low latency communications (URLLC).
7. Timing Advance:
  • LTE RACH:
    • Fixed timing advance adjustment.
  • 5G NR RACH:
    • More dynamic and accurate timing advance mechanisms to support higher frequencies and wider bandwidths.
8. Message Formats and Sequences:
  • LTE RACH:
    • Limited message formats with a predefined sequence.
  • 5G NR RACH:
    • More versatile message formats and sequences to accommodate diverse requirements and services.
9. UE Capability and Complexity:
  • LTE RACH:
    • Designed for simpler UE capabilities.
  • 5G NR RACH:
    • Requires more advanced UE capabilities to handle the flexibility and complexity of the RACH procedures.
10. Energy Efficiency:
  • LTE RACH:
    • Less emphasis on energy efficiency.
  • 5G NR RACH:
    • Improved energy efficiency mechanisms to support IoT and battery-operated devices.
These differences highlight the advancements in 5G NR RACH over LTE RACH, making it more suitable for the diverse and demanding requirements of 5G networks.
