Fixed wireless access (FWA) is a type of technology that uses radio waves to provide high-speed internet access to homes and businesses. It is an alternative to traditional wired broadband connections, such as cable or fiber optic.
FWA systems typically consist of a base station, which is connected to a fixed network, and a subscriber unit, which is located at the customer’s premises. The base station uses radio waves to communicate with the subscriber unit, which then provides the customer with internet access.
FWA can be used in a variety of settings, including rural areas, where wired broadband is not available or is too expensive to install. It can also be used in urban areas, where there is high demand for internet access and wired networks are congested.
The speed of FWA connections can vary depending on the technology used and the distance between the base station and the subscriber unit.
Here are some of the advantages of FWA:
- It can be used in areas where wired broadband is not available or is too expensive to install.
- It can provide speeds that are comparable to wired broadband connections.
- It is a relatively quick and easy way to deploy internet access.
Here are some of the disadvantages of FWA:
- The speed of the connection can be affected by weather conditions and the distance between the base station and the subscriber unit.
- It can be more susceptible to interference than wired broadband connections.
- The cost of FWA can be higher than the cost of traditional wired broadband connections.
Here are some of the factors to consider when choosing a fixed wireless access provider:
- The cost of the service
- The coverage area
- The customer service reputation
Difference B/W Broadband /5G FWA/4G FWA:
Broadband: Broadband is a general term for any high-speed internet connection. It can be delivered over a variety of technologies, including cable, fiber optic, and DSL. Broadband typically offers speeds of up to 100 Mbps, but can be faster in some cases.
5G FWA: 5G FWA is a type of fixed wireless access that uses 5G technology to provide high-speed internet access. 5G FWA can theoretically reach speeds of up to 10 Gbps, but actual speeds will vary depending on the location and the availability of 5G coverage.
4G FWA: 4G FWA is a type of fixed wireless access that uses 4G technology to provide high-speed internet access. 4G FWA can typically reach speeds of up to 1 Gbps, but actual speeds will vary depending on the location and the availability of 4G coverage.
If you need the fastest speeds and lowest latency, then 5G FWA is the best option. However, if you are on a budget or if 5G coverage is not yet available in your area, then 4G FWA or broadband may be a better option.
LinkedIn:
