ITL means interleaver
It’s multiplexer and demultiplexer
Used to combine and separate even and odd WDM channels
It has 2 types :
ITL U
ITL B
- U is unidirectional
- B is bidirectional
It can combine even / odd channels spaced by 100 GHz to 50 GHz
It’s recommend for upgrade scenarios and expansion
It can be connected between optical amplifier and Multiplexer or SFD
Note : SFD is static filter multiplexer and demultiplexer
WR is wavelength router
It’s a very important WDM system block
Used to add / drop and pass through channels in WDM, network
When the traffic enter the WR , it can be directed flexibily to any direction
It can contain WSS ( wavelength selective switch )
WSS responsible for traffic routing
WR can be controlled by software remotely
It contain add ports n, drop ports and THRU ports for passing through traffic for aggregated channels
LinkedIn:
