What is PUCCH format selection criteria for 5G?
When retx format 2 is selected, due to which retx failing, while if it’s pucch 0 selection than it’s working fine.
Any idea how algorithm selecting format 2?
Thanks…
Thanks…
Is there any rate matching of PUSCH around PUCCH formats in NR? | 0 | 412 | March 13, 2021 | |
Basic PUCCH parameters for 5g SA | 1 | 867 | March 7, 2022 | |
Whats the meaning of 'deltaPRI ' parameter for pucch allocation? | 0 | 504 | September 8, 2021 | |
Criteria for choosing Frame Slot Configuration in 5G NSA deployment | 1 | 10 | October 19, 2024 | |
Can same information be transmitted in PUSCH than PUCCH? | 1 | 283 | September 13, 2023 | |
Does network perform the CRC check on the UCI? | 1 | 449 | July 3, 2020 | |
What is normal range of number of PUCCH retransmissions before UE moves to RACH? | 0 | 243 | December 29, 2023 | |
How are 5G PDCCH candidates monitored by UE and how PDDCH scheduling algorithms works? | 0 | 459 | July 19, 2020 | |
UE not sending ACK PUCCH Format 1A for MSG4 | 0 | 291 | January 5, 2024 | |
Pusch restrictions | 0 | 568 | November 25, 2021 |
