GSCN define the center frequency of SSB(PSS,SSS& PBCH) and it can be any where in defined channel BW as per the table and calculation given by 3gpp but in legacy technologies it was fixed at the center of the channel BW.
Question is -> What is the benefit of flexible position of SSB in 5G then fixed at the center of the channel? what is the need to introduce GSCN in 5G?
I have some disconnect here.
I am under impression that at a time only 1 SSB will be transmitted.
Position of that can be changed as per BWP configuration.
It is necessary to identify center frequencies for both: Channel Bandwidth Set of SS/PBCH Blocks. Initial deployments are likely to use a single set of SS/PBCH Blocks requiring a single center frequency. More advanced deployments may use multiple sets os SS/PBCH Blocks requiring multiple center frequencies, e.g. when a channel bandwidth is configured to use multiple BWP.
Question is: what are the benefit to introduce GSCN other then larger raster compare ARFCN?
