Can anyone tell what is the difference between cell reselection and IRAT Handover,
Which one takes place in idle mode and which one in dedicated mode?
Admin note: updated post with image below.
Hello @navinray91.
Cell Reselection happens only when the UE (or Mobile Phone) is in Idle MODE, and the UE needs to go a more appropriate cell.
It’s a ‘way’ that UE uses to change the cell it is camped on, reselecting a ‘better’ cell.
For this, the UE follows a process (algorithms) and criteria.
When the UE is turned ON, it makes a Cell Detection/Search, than a Cell Selection and finally completes de Registration, and stays in IDLE Mode.
By constant measure of the RSRP/RSRQ values of this current cell it decides (via some criteria) if remains in this current cell (cell reselection criteria not met) or go finding another cell (cell reselection criteria met). (Note that if the RSRP/RSRQ are poor the UE restart from the beginning, as it was turned ON again).
As you can see, cell reselection criteria is the most important set of parameters for having good cell reselection, and it is mainly defined by Absolute Priority, Radio Link Quality and Cell Accessibility.
Now for the IRAT Handover.
As the name states, it is the handover that happens among different RAT (Radio Access Technologies). So, IRAT HO stands for Inter Radio Access Technologies Handover. RAT can be either GSM, UMTS, LTE or any other wireless technology that is used by the UE.
Differently from Cell Reselection, IRAT HO happens when the UE is in CONNECTED mode (but just like in the former, the UE needs to go a more appropriate cell).
The UE change its cell and goes to another cell; but in this case the UE has an active call (connection).
Also like in Cell Reselection, the UE follows a process (algorithms) and criteria. (Actually, this ‘general’ logic is almost the same – or at least very similar - in any type of handover/selection/reselection/redirection, in every technology – based on measurements and values of parameters (timers, triggers, events, etc.), follows a workflow to evaluate ‘what to do’).
The UE connected in one RAT stays continuously performing several measures, for its current cell and its neighbors (including other RATs), and send this information to the network. The network, based on the measurement report received from the UE, can decide if it’s better (or not) for the UE go to another RAT.
Although the IRAT HO decided upon UE measurements is more common, it is also possible to have IRAT HO decided only by Core Network (without measurements from the UE).
The Core Network plays a significant role to perform handover between RATs (it controls handover decision and handover procedure).
When the UE is in connection with a cell, we can have ‘situations’ that require the IRAT HO to be performed (i.e. UE going out of 3G coverage area for a 2G coverage area only).
The network see this situation, and ask measurements from the UE (for the probable new target cell) to evaluate the conditions.
If the evaluation indicates that is better for the UE to perform the handover, the network instructs the UE to change for the new cell, and it do so - and finally respond to the network, informing that everything is OK, and it is connected in the new target cell.
It’s clear that for the IRAT HO be successful it is very important to have proper parameters defined, as said before.
This is the main challenge we all (working with telecommunications) face every day, and you can see a ‘big picture’ with all main possible bellow.
Although it doesn’t cover every possible case, it shows the most common ones. And I believe can be a starting point to understand the basic concepts that we all must have.
Best Regards,
Raniele
Kindly explain me more about CSFB procedure when UE is idle mode and connected mode. Thanks in advance
Hello @Maxime_Netstat_Tchap
CSFB happens when a mobile needs to go back to a legacy network (2G/3G), to use its CS infrastructure to make a Voice Call.
You can find a better explanation (a little more detailed) here:
What is CSFB and SRVCC in LTE?
Hope that helps.
BR,
Leo
One basic difference is "In handover procedure, target cell would be prepared and UE will latch on target cell based on the configuration sent by source enodeb to UE. Whereas in re-direction, target cell would n’t be prepared for the Ue , And UE leave current cell and will try to latch on the cell/frequency, communicated by source eNB to UE.
So during handover procedure, UE will continue with the services which were being used by UE. But in case of re-direction, services will be interrupted.
Thanks for the explanation.
Hello,
When an UE switches from one technology to another, from 4G to 2G for example, but it always stays in the same cell, is this called an IRAT HO, even if it does not change the cell ?
And thank You!
If the UE switches from one RAT to another RAT, it will not stay in the same cell!
Yes, I agree. There is no way do IRAT HO and stay in same cell.
