Hello experts!
What is the difference between SS-RSRP and SSB-RP measures?
Is there any difference to these names, or is it the same measurement parameter?
(RSRP measured in SSB NR)
Thank’s
Hello experts!
Thank’s
Please check forum, it was already explained here: What are difference between SSB-RSRP & CSI-RS RSRP in 5G NR?
The key difference lies in the scope of the measurement:
SS-RSRP:- measures the received power of the synchronization signal across the entire cell bandwidth, giving a general indication of signal strength.
SSB-RP:- measures the received power specifically related to the SS block within the cell, which is used for more precise synchronization and initial access procedures.
Both parameters are important for proper network synchronization and initial UE attachment in 5G NR, but they serve slightly different purposes and are measured differently.
