Hi Experts. Do you de equivalent parameter in Ericsson to “ReferenceSignalPwr” for Huawei. I set this one with 18.2dBm.
REFERENCESIGNALPWR you find PDSCH M.O.
You can calculate Rs power in E/// with setting crsgain, pdschtypeb, bandwidth, configuration of power
Is it possible to have different value of rs power?
I have observed a changes in rs power from 18 to 19 in the same cell In idle mode.
I guess your setting with crsgain 300 and 20W/Port in BW:10MHz or 30W/Port on 15MHz
Dl attenuation is constant for one cell
And so is the bandwidth n crsgain then how the power is changed in sib2?
Please check your RRU Capability and license, configuredMaxTxPower, maximumTransmissionPower, noOfTxAntennas, noOfRxAntennas
All checked there is nothing problematic there.
Thanks. I will make a plan to calculate that.
