Hi, dears.
While I was checking sib1 log, I found there is a timealignmenttimercommon which is set as infinity. If the ue is in idle , has not sent RACH to the BS, then in my opinion, there is no need to have uplink time alignment with the BS. Then why does the BS broadcast a timealignmenttimercommon inside the cell? What is the meaning of this parameter?
Related Topics
NR5G RRC timer status = deadlock | 0 | 670 | June 11, 2021 | |
LTE and NR synchronization requirement during inter-RAT measurements | 1 | 907 | July 29, 2022 | |
5G VoNR drx parameters | 0 | 491 | August 29, 2023 | |
What is reason for UE to move for NR RRC inactive state? | 2 | 782 | June 29, 2021 | |
What is the significance of "Frame timing offset of a cell" in 3G? | 0 | 445 | December 23, 2022 | |
Why does gNB need IE NeedforGapsInfoNR from the UE? | 0 | 242 | March 22, 2024 | |
Timer for UE to send scheduling request in 5G | 2 | 545 | February 23, 2021 | |
Time on Technology showing LTE in 5G UE Log | 3 | 498 | March 13, 2021 | |
TimeAlignmentTimer | 0 | 419 | July 11, 2022 | |
Recommended value for Reassembly Timer | 0 | 361 | March 21, 2022 |
