What is the role of CSI in 5G in Radio admission control Failure and Low Users?
If requested throughput, example for a GBR cannot be met in current radio conditions, then gNB admission control can reject that session.
NR SCG addition fails for 'reconfiguration failure' when NR CQI reporting is enabled | 2 | 342 | April 8, 2021 | |
NR throughput (NSA) when link adaptation is triggered | 3 | 627 | May 10, 2021 | |
Configuring CSI for NR spcell and NR scell in NSA | 0 | 321 | April 1, 2021 | |
What are the probable issues for a UE latched to 5G with no throughput? | 1 | 266 | August 31, 2023 | |
SgNB addition reguest rejections with cause: no radio resource available | 5 | 1178 | September 12, 2024 | |
What can influence gNb decision of number of layers except RI? | 0 | 290 | May 2, 2021 | |
DRB addition failure | 1 | 770 | October 31, 2021 | |
If CSI report slot falls on ack/nack slot then shall UE drop csi report? | 2 | 309 | March 25, 2022 | |
Any counters to find failures in admission control if UE doesn't support DSS? | 4 | 611 | October 15, 2022 | |
How UE indicate the presence of csi part 2? | 0 | 1424 | March 15, 2021 |
