Hello All.
Does anyone knows what is the UE penetration for UEs that support SRS in 5G in any network?
Just looking for general figures before activating SRS based beamforming in 5G.
Hello All.
Value of SINR below which UE will not be able to latch onto 5G network | 1 | 455 | September 11, 2023 | |
UEs supporting DSS | 4 | 915 | January 8, 2021 | |
Uplink Beamforming for FR2 | 1 | 28 | August 30, 2024 | |
UE positioning using PRS | 2 | 463 | March 27, 2023 | |
How IE to check if the device support DSS? | 1 | 702 | February 24, 2021 | |
BSR reasonable implementation in 5G NR | 1 | 645 | March 31, 2022 | |
In what conditions network / gNB will not give SRS configuration with "usage- antennaswitching"? | 0 | 113 | March 16, 2024 | |
Guide to Checking N71 (600 MHz) 5G Band Supported UE Details | 7 | 22 | November 18, 2024 | |
Is anyone aware of UEs with beamforming in Uplink on transmission for NR? | 1 | 14 | August 25, 2024 | |
What is the SS-RSRP threshold for 5G NR on the 3.5 GHz band to determine good coverage? | 10 | 264 | October 14, 2024 |
