What parameters “n1n2” and “nTransmissionScheme” means for 4x4 MIMO?
Check MIMO 2x2 & 4x2 | 0 | 503 | August 26, 2021 | |
E/// NR Power Parameters | 0 | 383 | February 27, 2023 | |
Basic PUCCH parameters for 5g SA | 1 | 868 | March 7, 2022 | |
What is the significance of N1 and N2 in codebook? | 1 | 476 | June 18, 2021 | |
How transmission scheme with 1 or 2 code word with upto 8 layers are related to number of beam, SU MIMO (closed loop & open loop) and MU MIMO? | 0 | 742 | October 14, 2020 | |
What is the max throughput for 4x4 MIMO with 5MHz BW? | 1 | 1299 | September 24, 2017 | |
What is dual slant ports of 8x8 / 4x4 MIMO antenna? | 1 | 381 | May 10, 2021 | |
In 4G, what is the difference between MIMO 2T2R ans 2T4R in terms of Throughput and Coverage? | 1 | 1912 | September 14, 2022 | |
What is the meaning of system constant ON/OFF parameters in 5G? | 0 | 125 | June 6, 2024 | |
Meaning of 5G n-1 in AP Logs | 1 | 30 | September 18, 2024 |
