Hi All.
UE does not report B1 NR measurement reports to setup the NR when temperature is over 42-43 degrees.
But can’t remember is it battery temp or chip temp?
Hi All.
It’s battery temperature.
For some chipset vendor you can override it if you open developer mode, but it’s not recommended.
