SM is single mode
MM is multi mode
SM has 9 micrometer core diameter
MM has 50-62 micrometer core diameter
SM used in long distances transmission
MM used for short distances transmission
SM used in WDM technology ( specially DWDM )
SM should use Single mode SFP
SFP is small form factor pluggable and it’s the optical module that convert optical to electrical and vice versa
We can use 1310 and 1550 nm in single mode
We can use 850 nm in multimode
SM has higher immunity to modal dispersion
ITU standardize G 652 , G 653 and G 655 to work in single mode optical
G 652 and G 655 is the most common single mode optical fiber used in DWDM technology
G 653 can be used in SDH
We can’t use G 653 in DWDM because it’s zero dispersion point is in 1550 nm and it can lead to four wave mixing
Credits:
