Hello All.
Whether increasing the max no of users per TTI increase the cell throughput?
Hello All.
Adjusting the edge users power can help more.
But “No” for your question.
Cell throughput = average user throughput * number of user in the cell → Mathematically
So when you increase the number of users per TTI you are just acting on the capacity aspect and will impact the user throughput.
Now to have high cell throughput you should have good coverage showing that users are having almost same experience. More cell edge users with bad coverage will lead to low cell throughput no matter how much UE are set per TTI.
Someone can adjust if I am wrong…
Yes, I agree.
I see that Cell throughput KPI is not a clear indicator for user experience, but User Throughput is.
Cell throughout is more reflecting the traffic in the cell.
I agree, but it depends on what you want to evaluate.
When you say “edge users power” - is there a specific parameter which can do that?
Proportional fair strategy
Fast MIMO
UL adaptation
SRS
Scheduling Method
SCH/CCH Power Lev Low Up
