Which is the most common bit rate used in VoLTE calls either in AMR WB EVS categories?
Hi. One of the most common is 24.4kbps. Called too SWB… I believe that 13.2kbps is a good option because use less resources and has the similar MOS but my advice is to do tests and see the best value use aligned with the strategy of the network…
Hello @eta004 , @Evaldo_Silva …
In which message can I know VoLTE call rate?
