Because of the Guard Band (narrow frequency range that separates two ranges of wider frequency, in order to avoid interference which would result in decreased quality for transmission).
Bandwidth directly affects the throughput. Different BWs have different number of RBs.Here is the calculation how to find out the numbers of subcarriers and Resource Blocks.10% of total bandwidth is assumed to be used for guard band. Though 10 % guard band assumption is not valid for 1.4 MHz bandwidth. Let’s take an example of 20MHz.10% of 20 MHz is 2 MHz, used as guard band, thus effective bandwidth will be 18MHz. Number of subcarriers = 18 MHz/15KHz = 1200. Number of Resource Blocks =18 MHz/180KHz = 100. Same calculations can be done with other bandwidths to calculate the number of subcarriers and Resource Blocks.
Hi Vinod,
Per 3GPP, there are conditions like if no. RBs>10 than CFI = CFI else if no. of RBs<10 than CFI=CFI+1…
So for 1.4 Mhz, there’s only 6 RB that’s we used CFI +1 else for other B.W 3MHz to 20MHz CFI is used same.
2nd
Min. allocation for 1 UE is about to 1CCE (9REG’s) that’s equal to 36 RE’s but for CFI=1 ( like 6 RBs) case can’t meet this req. so need to give CFP+1 so meet the at least minimum critera.
