This table is for TDRA signaling in UL grant.
It seems in 38.212 for DCI 0_1 we may use up to 6 bits to signal this field.
Anyone knows why 6 bits are used?
In Rel10, what are those 4 bits in format1b used for? | 4 | 468 | December 30, 2021 | |
Does anybody have idea on why DCI formats 0_2 and 1_2 are introduced in Rel16? | 3 | 2626 | October 3, 2021 | |
DL Grant Count max value of 1600/second regardless of SCS and Bandwidth | 1 | 827 | May 17, 2021 | |
Why there is more subcarriers in Downlink than Uplink? | 3 | 761 | October 30, 2021 | |
Whats is the use of field: "symbol allocation index" in DCI 0_0/0_1 in QXDM packet? | 3 | 79 | September 7, 2024 | |
What is the meaning of the field dai_bit in DCI format? | 0 | 463 | November 2, 2021 | |
UE maximum number of blind decoding | 0 | 266 | January 23, 2023 | |
Why 16harq processes in 5G? why not 32 or 64? | 2 | 552 | November 20, 2022 | |
Bandwidth supported indicated 2 times for NR | 0 | 374 | April 12, 2022 | |
What is the reason for Analog Beam Forming in > 6 Ghz? | 2 | 414 | October 16, 2020 |
