Why KPI counter AVERAGE NSA NUMBER OF USERS is crossing 24000 value in 15 min rop data?
Vendor is Nokia.
Vendor is Nokia.
Divide it with AVE_NUMBER_OF_NSA_USERS_DENOM counter to get the users count.
What you are getting is aggregated samples.
RAN Vendors KPI calculations | 2 | 343 | September 1, 2023 | |
Check average PRB used in VoLTE calls | 1 | 463 | June 23, 2023 | |
How to tell from traces if the user is being served by 5G NSA or 4G in Core? | 3 | 246 | April 17, 2024 | |
5G standalone performance counters and KPI | 4 | 1380 | November 16, 2023 | |
UR_Qual_SCR_L Quality score | 0 | 395 | March 14, 2021 | |
NB-IoT Volume & Others Counters | 1 | 956 | February 18, 2022 | |
Samsung KPI formulas | 1 | 835 | October 29, 2020 | |
5G NSA RE Power check using drive test | 2 | 559 | April 6, 2023 | |
Nokia KPI for Tracking Timing Advance (TA) and Creating a Time-Distance Chart | 5 | 83 | August 30, 2024 | |
QCI KPI commands | 7 | 2295 | February 1, 2024 |
