- Why PCI mod 6 is used for 5G TRS?
As per the configuration of TRS it should be PCI mod 4.
PCI MOD for different MIMO | 11 | 2422 | June 5, 2021 | |
PCI cell planning in 5G | 4 | 3539 | February 25, 2021 | |
5G PCI planning | 4 | 2545 | February 8, 2023 | |
CSI-RS Tracking Reference Signal | 0 | 2361 | April 6, 2023 | |
PCFICH channel in 5g nr sa | 3 | 976 | September 1, 2022 | |
Can same PCI in 3 km range cause issue (5G SA)? | 7 | 563 | May 5, 2023 | |
5G NR ScellIndex configuration | 6 | 3123 | May 24, 2020 | |
For 5G, what scenario leads to use of 32 ports for csi-rs? | 3 | 2076 | March 4, 2022 | |
Why first and seventh cyclic prefix is larger in 5G in each slot? | 3 | 168 | July 28, 2024 | |
Deciding factor for sCellIndex definition | 0 | 640 | July 1, 2020 |
