Here’s why.
WiFi 7 a significant improvement over WiFi 6.
It’s much faster (on paper it’s ~4.8x faster than WiFi 6).
Here are 12 key advancements of WiFi 7:
Data density → 4096 QAM
Carrier aggregation → Multi-link operations
Inter-cell interference → Controlled
Peak data rate → Up to 46.4 Gbps
Spatial streams → 16
Supported frequencies → 2.4, 5, 6 GHz
Bands → Low and mid band
Bandwidth → Up to 320 MHz
Channel access → OFDMA
Protocol → 802.11be
Security → WPA 4
Resource unit → Multi-RU support
Here’s why it matters:
Businesses:
- WiFi 7 enables peak efficiency.
- Faster speeds mean better productivity.
Entertainment:
- Fewer lags.
- Almost no buffering.
Smart Homes:
- It keeps all your smart devices online.
- Every device, every time.
WiFi 6 still works fine.
And, many devices still use it.
But understanding these differences is important.
It helps you choose the right technology.
So, make informed choices with the right WiFi.
Thanks for reading.
LinkedIn:
