So you are a Python user… and you are used to LAMBDA functions…
Even if you’re not a Python user, you may know LAMBDA functions are powerful function in a lot of languages.
And what if i say you can have LAMBDA functions in Excel too?
Yes, Excel allows you to create LAMBDA functions.
Basically, you create a function that works and then turn it into a LAMBDA.
Lambda (as Leila explains) is a kind of “machine” where you add the “ingredients”.
Curious to know this function?
Watch this short video, and grow together.
YouTube: Excel LAMBDA - HOW & WHEN you Should use it - YouTube
