ZTE 2G error during global validity check
Anyone have idea of below error.
Validity check of global data does not pass!
[ERROR] The max number of different BCCHARFCN of IBTSHO and IBTSHORES is 31 when ‘CS measurement type reported by UE’ is 1.
[ERROR] The max number of different BCCHARFCN of IBTSRESL and IBTSHORES is 31 when ‘CS measurement type reported by UE’ is 1.
[ERROR] Strategy for E-Utran Neighbour Select When Release’ is 0 or 2, normal measurement report,the count of ho,hores,adjacent E-UTRAN arfcn must be less than 32.
[ERROR] The max number of different BCCHARFCN of IBTSHO and IBTSHORES is 31 when ‘CS measurement type reported by UE’ is 1.If measure BCCH when in subcell2(Subcell2MeasureBcch) is 1, the BCCHARFCH of the cell will be included.
[ERROR] The max number of different BCCHARFCN of IBTSRESL and IBTSHORES is 31 when ‘CS measurement type reported by UE’ is 1.If measure BCCH when in subcell2(Subcell2MeasureBcch) is 1, the BCCHARFCH of the cell will be included
What are u trying to implement.
hello,
i belive you’re trying either to change or add some Nighbour relation and the number of relation for specific frequency is almost 32 , so you have to decrease the nighbor list and try again, meawhile in order to support you for correction, please share the excell file, that you are trying to implement
respects.
Full neighbour.
Gsmrelation. One cell BCCHARFCN cannot more than 31.
Just delete some unnecessary neighbour.
Resolved you are right having the same issue.
Thanks for the support issue has been resolved after deleting the extra relations.
